Aller au contenu principal
Razer Naga Epic Chroma Disassembly
Ce dont vous avez besoin
  1. Razer Naga Epic Chroma Disassembly, Razer Naga Epic Chroma Disassembly: étape 1, image 1 de 1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Disassembly: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Disassembly: étape 3, image 1 de 1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Disassembly: étape 4, image 1 de 1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
12 autres ont terminé cette réparation.
Jordan Morgan
Membre depuis le 01/19/17
886 Réputation
6 tutoriels rédigés
Équipe
3 commentaires
where can i get new teflon tape ???
Kieran jones - Réponse
This guide is excellent, to further it, you must take out another screw near the battery compartment and 2 on the inside of the compartment to completely take off the board to be able to clean the lense if you are having random mouse jumps and non responsiveness from the mouse, I did that and now it works like new after re-assembly. I used 70% alcohol with cotton swabs to thoroughly clean everything including the lens.
King Gosuto - Réponse
Hi, can you please tell me where can I find a grip (right side) for my Razer Naga Epic mouse.
Ghufran Muhammad -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 21
30 derniers jours : 138
Total : 25,398
