Aller au contenu principal
Razer Naga Epic Chroma Scroll Wheel Replacement
Ce dont vous avez besoin
  1. Razer Naga Epic Chroma Scroll Wheel Replacement, Razer Naga Epic Chroma Disassembly: étape 1, image 1 de 1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Scroll Wheel Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Scroll Wheel Replacement: étape 3, image 1 de 1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Scroll Wheel Replacement: étape 4, image 1 de 1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
  5. Razer Naga Epic Chroma Scroll Wheel Replacement, Scroll Wheel: étape 5, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the single screw adjacent to the wheel.
  6. Razer Naga Epic Chroma Scroll Wheel Replacement: étape 6, image 1 de 1
    • Use your fingers to pull back on the plastic between the scroll wheel and the battery mount.
    • Keep pulling this tab gently towards the battery mount until the scroll wheel has been removed.
  7. Razer Naga Epic Chroma Scroll Wheel Replacement: étape 7, image 1 de 1
    • Unplug the wheel cable connecting to the board.
  8. Razer Naga Epic Chroma Scroll Wheel Replacement: étape 8, image 1 de 1
    • Remove the scroll wheel from the mount.
Jordan Morgan
Membre depuis le 01/19/17
895 Réputation
6 tutoriels rédigés
Équipe
Un commentaire
where can i get a replacement Scroll wheel?
William Jansen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 27
Total : 4,706
