Aller au contenu principal
Razer Naga Epic Chroma Top Casing Replacement
Ce dont vous avez besoin
  1. Razer Naga Epic Chroma Top Casing Replacement, Razer Naga Epic Chroma Disassembly: étape 1, image 1 de 1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Top Casing Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Top Casing Replacement: étape 3, image 1 de 1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Top Casing Replacement: étape 4, image 1 de 1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
  5. Razer Naga Epic Chroma Top Casing Replacement, Top Plastic Casing: étape 5, image 1 de 1
    • Plug the new top casing's cable back into the socket on the right side of the circuit board near the middle.
    • Reassemble the device.
    • Test device to make sure the connections function correctly.
Jordan Morgan
Membre depuis le 01/19/17
886 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 1,809
