Introduction
This prerequisite guide is to help users disassemble the mouse. The mouse needs to be mostly disassembled in order to complete most of the tasks needed to fix any issues.
Put on the anti-static wrist strap to protect you from electrostatic discharges during your repair.
Outils
Pièces
Aucune pièce spécifiée.
12 autres ont terminé cette réparation.
6 commentaires
I would like to to point out that at step 7, second picture, the 3-pin connector is for the top 2 buttons. the RGB LED is actually in the board and can be seen in step 7 first picture, tiny white square at the bottom, top left where it says K7-D1.
The cable for the Naga2014 fits admirably and appears to work fully, BUT NOTE: the green and white wires need to be swapped around in the plug at the end that connects inside the mouse.
How do you remove the board so that you can replace the mouse buttons when they break?
It’s held in by four screws - left of the bottom edge of the wheel’s rearward mounting bracket, just forward of the main cable connector on the right, and either side of the wheel’s forward mounting bracket.
To access the forward wheel mounting bracket screws, it’s easier if you first remove the wheel (it’s located by lugs/pins at front and back) by carefully bending the front mounting bracket forward to allow enough clearance for that lug/pin to be pulled clear.
Make a mental note of the arrangement of the front mounting parts for reassembly.
