Aller au contenu principal
Razer Naga Trinity LED Light Ribbon Cable Replacement
Ce dont vous avez besoin
  1. Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: étape 1, image 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: étape 1, image 2 de 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LED Light Ribbon Cable Replacement: étape 2, image 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: étape 2, image 2 de 2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LED Light Ribbon Cable Replacement: étape 3, image 1 de 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LED Light Ribbon Cable Replacement: étape 4, image 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: étape 4, image 2 de 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LED Light Ribbon Cable Replacement: étape 5, image 1 de 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LED Light Ribbon Cable Replacement: étape 6, image 1 de 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LED Light Ribbon Cable Replacement: étape 7, image 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: étape 7, image 2 de 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: étape 8, image 1 de 2 Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: étape 8, image 2 de 2
    • Using the flat end of a spudger, unlock the ribbon cable holding the clips.
    • Remove the ribbon cable.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 1,503
