Aller au contenu principal
Razer Ouroboros Battery Replacement
Ce dont vous avez besoin
  1. Razer Ouroboros Battery Replacement, Battery: étape 1, image 1 de 1
    • Begin by turning the mouse upside down.
    • Use a Phillips #00 to loosen the two captive screws circled in the first image.
    • These screws do NOT come out, they merely loosen.
    • Slide the palm rest toward the back of the mouse. It should slide down its track and come right off.
  2. Razer Ouroboros Battery Replacement: étape 2, image 1 de 1
    • This is the bottom of the palm rest.
    • Turn the knob highlighted by the red circle will change the height of the palm rest for maximum comfort.
  3. Razer Ouroboros Battery Replacement: étape 3, image 1 de 1
    • The battery compartment is on the back side and is easily viewed once the palm rest is removed. Simply push up gently and the hinged battery door opens from the bottom
    • Place the new battery into circular slot shown in the picture. The battery should be placed in positive side first.
    • You must use rechargeable batteries in this mouse.
7 autres ont terminé cette réparation.
Brandon Jones
Membre depuis le 07/19/16
308 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 1-2, Kim SU 2016 Membre de l'équipe University of Memphis, Team 1-2, Kim SU 2016
UM-KIM-SU16S1G2
3 membres
4 tutoriels rédigés
8 commentaires
is the battery a standard AA battery size or did they use a different size?
adiforipod - Réponse
Standard AA size mate
Minty Fox - Réponse
… what happens if I don't use a rechargeable battery?
Russell Phillips - Réponse
Its fine… You just need to remember not to put it on the recharging base… and the battery will be basically dead after 24 hour use.
flamespinner1 -
will any brand battery work or does the stock one have specific specs?
ThrowsMachete - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 21
30 derniers jours : 68
Total : 19,257
