Aller au contenu principal
Razer Ouroboros Scroll Wheel Replacement
Ce dont vous avez besoin
  1. Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: étape 1, image 1 de 3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: étape 1, image 2 de 3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: étape 1, image 3 de 3
    • Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse.
    • Slide the palm rest out of place.
  2. Razer Ouroboros Scroll Wheel Replacement: étape 2, image 1 de 2 Razer Ouroboros Scroll Wheel Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse.
    • Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
    • Use the Phillips #00 Screwdriver to remove these two, 3mm screws.
    • Slide the side panels off of the mouse.
    • Use your tweezers to take the lock switches off of the mouse.
    • Using the T6 Torx screwdriver, remove the two bottom 4mm screws as indicated in the second picture.
  3. Razer Ouroboros Scroll Wheel Replacement: étape 3, image 1 de 3 Razer Ouroboros Scroll Wheel Replacement: étape 3, image 2 de 3 Razer Ouroboros Scroll Wheel Replacement: étape 3, image 3 de 3
    • Using the T6 Torx screwdriver, remove the two 4mm screws hidden in the deep holes indicated in the first picture.
    • Slide the top panels off of the mouse.
    • Flip the mouse over, and the mouse casing should come off.
    • There are some connectors connecting the casing to the motherboard. They should slide off. Just be careful not to break them.
  4. Razer Ouroboros Scroll Wheel Replacement: étape 4, image 1 de 3 Razer Ouroboros Scroll Wheel Replacement: étape 4, image 2 de 3 Razer Ouroboros Scroll Wheel Replacement: étape 4, image 3 de 3
    • Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it.
    • Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver.
    • Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
    • Take note of the orientation in the final picture so that you can place the wheel back correctly into its mechanism.
5 autres ont terminé cette réparation.
Preston Darling
Membre depuis le 07/26/16
372 Réputation
2 tutoriels rédigés
Équipe
University of Memphis, Team 1-2, Kim SU 2016 Membre de l'équipe University of Memphis, Team 1-2, Kim SU 2016
UM-KIM-SU16S1G2
3 membres
4 tutoriels rédigés
Un commentaire
Hello, one question, did the scroll click break, is it the same procedure?
Jorge Bestani (Ayman) - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 4,212
