Introduction
If the vibration motors for your Razer Wolverine V2 Chroma RZ06-0401 are not functioning as intended, such as the controller is vibrating when not supposed to or is not vibrating when supposed to, use this guide to replace the vibration motors.
The vibration motor is sent signals to vibrate from the controller motherboard to make gaming more immersive.
Before beginning, make sure to unplug your controller from any external power source.
Ce dont vous avez besoin
Using an opening tool, pry off the the outer front plate.
Once the front plate is loose, pull it off.
Remove ten 9 mm screws from the controller using a Phillips #000 screwdriver.
Locate the right vibration motor on the bottom right corner on the front of the controller.
