Aller au contenu principal
Razor Hovertrax 2.0 Battery Replacement
Ce dont vous avez besoin
  1. Razor Hovertrax 2.0 Battery Replacement, Battery: étape 1, image 1 de 2 Razor Hovertrax 2.0 Battery Replacement, Battery: étape 1, image 2 de 2
    • Use a #2 Philips screwdriver to remove the eight 18.5 mm screws from the bottom of the Hovertrax 2.0.
  2. Razor Hovertrax 2.0 Battery Replacement: étape 2, image 1 de 2 Razor Hovertrax 2.0 Battery Replacement: étape 2, image 2 de 2
    • To remove the led connector from the board, press the clip in with your fingers and gently pull up.
    • The connector you are removing is black and has two pins.
    • If it does not want to come out, gently wiggle the connector side to side while pulling up.
  3. Razor Hovertrax 2.0 Battery Replacement: étape 3, image 1 de 1
    • Disconnect the battery connector by grabbing the black side with one hand and the yellow side with the other hand and gently pull apart. (Try not to pull on the wires, it could damage them)
    • If you are replacing other parts, leave the battery disconnected until the end.
  4. Razor Hovertrax 2.0 Battery Replacement: étape 4, image 1 de 2 Razor Hovertrax 2.0 Battery Replacement: étape 4, image 2 de 2
    • Remove the two 17.2 mm hex head bolts using the 4 mm hex screwdriver that secures the battery in place.
  5. Razor Hovertrax 2.0 Battery Replacement: étape 5, image 1 de 1
    • The battery should be able to be lifted up out of the device now.
Dang Nguyen
Membre depuis le 09/08/23
217 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 38
Total : 236
