Introduction
Use this guide to replace the battery component of the Razor Hovertrax 2.0.
The battery serves as the powerhouse of the board, providing the necessary energy to drive the motors of the wheel and control the board's movements.
It is located under the plastic panel adjacent to the charging port.
Be mindful of the circuit board, for there is a charged capacitor active. Be careful because if you accidentally touch it, it will send a shock to your body with a high amount of amps.
Ce dont vous avez besoin
Use a #2 Philips screwdriver to remove the eight 18.5 mm screws from the bottom of the Hovertrax 2.0.
