Introduction
Prerequisite-only guide for removing the rear height-adjustable axle on the Toro Walk Behind Mower 21199HD 2018.
Ce dont vous avez besoin
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Chock the rear wheels to prevent the mower from rolling during service.
While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
Remove the grass bag.
Set the height adjustment lever all the way forward, past the "A" setting, to loosen the axle spring underneath the mower.
Tilt the mower onto its side so the blades are facing out.
Reach underneath the axle, near the transmission, and pull the axle spring out towards the axle and down to unhook it.
Return the mower back to an upright position.
Place the mower on blocks so each wheel is above the work surface and can rotate freely.
Remove the height adjustment lever from the left side of the mower.
Holding the left end of the axle with your left hand and the right end of the driveline with your right hand, firmly pull them in opposite directions—the axle to the left, and the driveline to the right.
While maintaining these opposing forces, squeeze both axles together.
