Aller au contenu principal
Rear Turn Signal Bulb Replacement
Ce dont vous avez besoin
  1. Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: étape 1, image 1 de 3 Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: étape 1, image 2 de 3 Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: étape 1, image 3 de 3
    • The stop/turn signal bulb is located in the outer rear lamp unit that is secured at the rear of each quarter panel
    • Open the tail gate and locate the two fasteners holding the light assembly to the quarter panel.
    • Locate the notches in the outer ring of the fasteners. Those are to facilitate the use of a screw driver to remove the fasteners.
  2. Rear Turn Signal Bulb Replacement: étape 2, image 1 de 3 Rear Turn Signal Bulb Replacement: étape 2, image 2 de 3 Rear Turn Signal Bulb Replacement: étape 2, image 3 de 3
    • Insert a flathead screwdriver or similar tool and pry out the center of the fastener
    • A pair of pliers, or similar tool, can be used to get a better hold on the fastener
    • Completely remove the fastener
  3. Rear Turn Signal Bulb Replacement: étape 3, image 1 de 3 Rear Turn Signal Bulb Replacement: étape 3, image 2 de 3 Rear Turn Signal Bulb Replacement: étape 3, image 3 de 3
    • Proceed the same way with the bottom fastener. Pry out the center.
    • Use pliers or similar tool to pull the fastener
    • Completely remove fastener
  4. Rear Turn Signal Bulb Replacement: étape 4, image 1 de 3 Rear Turn Signal Bulb Replacement: étape 4, image 2 de 3 Rear Turn Signal Bulb Replacement: étape 4, image 3 de 3
    • The tail light assembly is still held in place by two guide pegs. Gently pull the complete assembly toward the rear of the vehicle to unseat the pegs.
    • Fully remove the tail light assembly
    • The assembly can rest on the top of the rear bumper. The Stop/Turn signal bulb is the larger one of the two bulb fixtures.
  5. Rear Turn Signal Bulb Replacement: étape 5, image 1 de 3 Rear Turn Signal Bulb Replacement: étape 5, image 2 de 3 Rear Turn Signal Bulb Replacement: étape 5, image 3 de 3
    • Remove the bulb socket by turning it about 1/4 turn in a counter clockwise direction
    • Remove the socket from the light assembly
    • Remove the bulb from the socket by pulling it straight out.
  6. Rear Turn Signal Bulb Replacement: étape 6, image 1 de 1
    • Replace the burned out bulb with a new type 3057 dual filament bulb
3 autres ont terminé cette réparation.
oldturkey03
Membre depuis le 09/29/10
812 145 Réputation
119 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
45 membres
702 tutoriels rédigés
5 commentaires
What if the trunk don’t open is it possible to change a blinker bulb ?
Shellie Gill - Réponse
No. Step 1 picture 2 can't be accessed if it does not open
oldturkey03 -
I'm a female and I will give it a try.
janice_montalto - Réponse
1*Onde posso ter informações de como trocar a lampada do farol dianteiro ?
2* Meu carro entrou água e agora as setas fficam piscando, algo q posso resolver ?
Tharles - Réponse
3* comprei um .módulo de tração que fica embaixo do banco do motorista , mais ao colocar o carro não reconheceu, com9 resolver?
Tharles - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 37
30 derniers jours : 106
Total : 19,439
