Aller au contenu principal
RedMax Trimmer Carburetor Replacement
Ce dont vous avez besoin
  1. RedMax Trimmer Carburetor Replacement, Carburetor: étape 1, image 1 de 3 RedMax Trimmer Carburetor Replacement, Carburetor: étape 1, image 2 de 3 RedMax Trimmer Carburetor Replacement, Carburetor: étape 1, image 3 de 3
    • Locate the red knob that locks the air filter cover to the air filter housing.
    • Rotate the knob clockwise.
    • Remove the air filter cover, exposing the air filter.
  2. RedMax Trimmer Carburetor Replacement: étape 2, image 1 de 2 RedMax Trimmer Carburetor Replacement: étape 2, image 2 de 2
    • Remove the air filter by gently pulling it away from the unit.
  3. RedMax Trimmer Carburetor Replacement: étape 3, image 1 de 3 RedMax Trimmer Carburetor Replacement: étape 3, image 2 de 3 RedMax Trimmer Carburetor Replacement: étape 3, image 3 de 3
    • The red panel hides a second screw. In order to expose it, locate the red choke lever on the right side of the air filter housing.
    • Push the red choke lever down.
  4. RedMax Trimmer Carburetor Replacement: étape 4, image 1 de 3 RedMax Trimmer Carburetor Replacement: étape 4, image 2 de 3 RedMax Trimmer Carburetor Replacement: étape 4, image 3 de 3
    • Be aware that there may still be gasoline in the lines.
    • Disconnect the yellow and black fuel lines from the carburetor assembly by pinching the clamp and sliding it down the tube.
    • Gently pull the yellow and black lines away from the assembly.
  5. RedMax Trimmer Carburetor Replacement: étape 5, image 1 de 3 RedMax Trimmer Carburetor Replacement: étape 5, image 2 de 3 RedMax Trimmer Carburetor Replacement: étape 5, image 3 de 3
    • Using the T27 screwdriver, unscrew the two 55mm screws that hold the air filter housing and carburetor to the trimmer.
    • Separate the carburetor from the trimmer and air filter housing.
  6. RedMax Trimmer Carburetor Replacement: étape 6, image 1 de 3 RedMax Trimmer Carburetor Replacement: étape 6, image 2 de 3 RedMax Trimmer Carburetor Replacement: étape 6, image 3 de 3
    • Unscrew the four 24 mm long screws that hold the carburetor together, using the #1 Phillips head screw driver.
    • Once the screws are removed, the rest of the carburetor should separate easily.
  7. RedMax Trimmer Carburetor Replacement: étape 7, image 1 de 3 RedMax Trimmer Carburetor Replacement: étape 7, image 2 de 3 RedMax Trimmer Carburetor Replacement: étape 7, image 3 de 3
    • Carefully remove the gaskets and carburetor and replace them in the same order that they were removed.
4 autres ont terminé cette réparation.
Kevin Ydrovo
Membre depuis le 02/28/17
299 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 59
Total : 5,260
