Introduction
You can easily access the auxiliary port through the guitar neck. This guide will show you how to replace the auxiliary port located at the bottom of the guitar.
Ce dont vous avez besoin
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
Gently lift up on the auxiliary port to remove it from the case.
Presque terminé !
