Aller au contenu principal
RedOctane X-Plorer Rubber Button Strip Replacement
Ce dont vous avez besoin
  1. RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: étape 1, image 1 de 2 RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: étape 1, image 2 de 2
    • Remove the controller's strap, which will be attached at the points in the red circles.
    • If your controller does not have a strap, move to the next step.
  2. RedOctane X-Plorer Rubber Button Strip Replacement: étape 2, image 1 de 1
    • Remove all nine 12mm screws around the perimeter of the body of the controller, using the Phillips #2 screwdriver.
    • Remove the two 15mm screws near the neck of the controller, using the Phillips #2 screwdriver.
  3. RedOctane X-Plorer Rubber Button Strip Replacement: étape 3, image 1 de 2 RedOctane X-Plorer Rubber Button Strip Replacement: étape 3, image 2 de 2
    • Using your hands, remove the body shell.
  4. RedOctane X-Plorer Rubber Button Strip Replacement: étape 4, image 1 de 1
    • Remove all seven 12mm screws on the neck of the controller using the Phillips #2 screwdriver.
  5. RedOctane X-Plorer Rubber Button Strip Replacement: étape 5, image 1 de 2 RedOctane X-Plorer Rubber Button Strip Replacement: étape 5, image 2 de 2
    • Using your hands, remove the top shell of neck.
  6. RedOctane X-Plorer Rubber Button Strip Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    Flathead 1.5 mm Screwdriver
    $5.49
    J'achète
    • Remove the left 1.5mm mm screw (as shown) on the key sensor board, using the 1.5mm flathead screwdriver.
    • Do not remove the other (right-side) screw on key sensor board, as this can cause damage to the circuitry.
  7. RedOctane X-Plorer Rubber Button Strip Replacement: étape 7, image 1 de 2 RedOctane X-Plorer Rubber Button Strip Replacement: étape 7, image 2 de 2
    • Using your hands, remove the rubber button strip.
  8. RedOctane X-Plorer Rubber Button Strip Replacement: étape 8, image 1 de 2 RedOctane X-Plorer Rubber Button Strip Replacement: étape 8, image 2 de 2
    • Using your hands, insert the replacement strip underneath the key sensor board.
  9. RedOctane X-Plorer Rubber Button Strip Replacement: étape 9, image 1 de 2 RedOctane X-Plorer Rubber Button Strip Replacement: étape 9, image 2 de 2
    • Align the black dots on the rubber strip with the corresponding button indicator before rescrewing key sensor board.
    • The first button will be "A" on Xbox and Wii, and "X" on Playstation.
Stephen Haning
Membre depuis le 09/30/21
169 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 231
