Introduction
The guitar strings often catch on the plastic case or wear over time. This guide demonstrates how to access the internal components of the strings and diagnose hidden problems.
Ce dont vous avez besoin
Remove the strap by pulling it off of the mounts located on the body and neck.
Using two hands, gently remove the two string rod fixtures.
A step is missed here, there is a circuit board covering these fixtures. I ended up following the other guide on here to remove it then came back
4 autres ont terminé cette réparation.
2 commentaires
This did not help.
I had a squeaking strum bar so I followed this guide to dismantle and clean the parts. Other than the one step missed in the guide it was easy to follow. It also stopped the squeaking!
