Aller au contenu principal
Introduction
The strum bar sensor board will often wear and stop working over time due to overuse. This guide demonstrates how to replace the strum bar sensor board.
Pièces
Aucune pièce spécifiée.
  1. Remove the strap by pulling it off of the mounts located on the body and neck. Remove the strap by pulling it off of the mounts located on the body and neck.
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a  screwdriver. Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver. These screws can also be Torx on some models.
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. Remove the five 12mm Phillips #1 screws along the neck with a  screwdriver. Pull off the top shell of the neck to expose the internal features. Pull off the top shell of the neck to expose the internal features.
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. Use a screwdriver to remove the four 14mm Phillips #1 screws  around the perimeter of the strum bar sensor board. Lift up on the strum bar sensor board to remove it from the case. Lift up on the strum bar sensor board to remove it from the case.
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
Riley
Membre depuis le 18/04/2018
643 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 39
Total : 1,456
