Introduction
Screen and / or digitizer are broken but the rest of the phone is still fully functional.
Ce dont vous avez besoin
Remove the upper speaker
Caution: When removing the speaker, the two parts of the speaker can separate from each other. They are only held together by two very thin copper cables!
The best way to get to the bottom of the speaker and pry it out carefully is by using the direction of the red arrow.
For testing purposes, the button bar, the screen and the battery can be connected.
Attention! When doing so, there is an increased risk of damaging the connections or the battery. Be very careful!
A long press on the bottom button should start the phone
Remove the cover from the two adhesive strips for the battery
Insert the battery and reconnect it.
Repeat the steps in reverse order to reassemble your device.
4 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
3 commentaires
Watch and pray ,global warming.
