Introduction
Is your charging port not working? Do you get up in the morning and find that your device is not completely charged, or when you move your mobile a little the charger disconnects because it is not fully in the port?
In this guide we will solve that problem, and we will set up a jig to keep all the tiny pieces and screws well organized so we don't lose them!
Usually these have an easy solution, but, we need to be careful and patient when opening up the mobile device. Now, we will go into more detail!
Ce dont vous avez besoin
We have to be very careful and have patience when opening the the device; you have to use a spudger and hold the opening with a guitar pick, a card or something similar.
When you open the device completely you have to be very careful, opening it like a book towards the left (with the screen on the table). We do this because there is a cable that we have to disconnect later (the one that connects the cover of the mobile to the fingerprint sensor).
As we continue, we remove the screw that holds the shield in place protecting the flex fingerprint sensor cable (step 2 in the PDF guide).
Remove the shield that protects the fingerprint sensor flex cable (step 3 in the PDF guide).
To finalize this step, we use a spudger to remove the orange flex cable that connects the cover to the body of the device. This needs to be done very carefully. Now, we put the rear cover in a safe place (step 4 in the PDF guide).
Now we need to remove the two screws the hold the shield in place (step 5 in the PDF guide).
Then we disconnect the two cables that are underneath the shield (with a spudger) after removing the shield protector with the nylon pliers or with a spudger (step 6 in the PDF guide).
We remove the six screws that we see in the image. ALERT! One of them is under a xiaomi sticker! (step 7 in the PDF guide)
We remove the vibration motor and the speaker (they are under the same module) using the nylon pliers.
With a spudger and much care, we disconnect the connector for the battery and the antennae (both marked in red).
Later we can remove the screw that we should store apart from the rest! (step 8 in the PDF guide)
Using the point of the spudger, or something similar, we use a little bit of leverage in the hole that is marked in blue. (step 9 in the PDF guide)
To reassemble your device, follow these instructions in reverse order. But take into account that the mobile will "NOT" function correctly until the back cover is installed correctly given that this cover connects the power and volume buttons to the body of the mobile and allows it to correctly function.
4 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
