Introduction
Un riel de carga roto causará la incapacidad de conectar el control directamente al Nintendo switch o la incapacidad de cargar los joy-con. esta guía te mostrará como reemplazar el riel de carga en el joy-con izquierdo
Antes de usar esta guía verifica potenciales pins doblados en el riel de carga que puedan ser doblados a su posición original. Si es posible prueba si el joy-con puede ser cargado desde una fuente externa o prueba si el problema es en realidad culpa del riel de sensor en el Nintendo switch.
Si el problema es el sensor de riel del Nintendo switch, entonces sigue esta guía: Remplacement du rail du Joy-Con gauche de la Nintendo Switch
Ce dont vous avez besoin
Usa el destornillador de 3 puntas Y00 para remover los 4 tornillos de 6mm de la parte trasera del Joy-con
29 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Richard Aguirre nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
14 commentaires
I did this and still doesn’t work. I also changed the rail on the console side too. Very carefully of course. Any ideas?
Hey Luis,
Can you give me more detail on the problem? Like is the Joy-Con not being detected when it’s plugged in or is it not charging. If possible, can you test the console rail with a working Joy-Con?
If the Joy-Con is not charging, it could also be a battery problem. If you are comfortable with it, I would suggest swapping out the battery with a working one from the other Joy-Con to see if it solves the problem. You should probably attempt this after double-checking the connections for potential tears or if the connectors are too loose in the sockets.
Hi, I need help. My left Joy-Con is not charging because of the ZIF connector for the charging rail ribbon has been detached and I have lost it. Is there a way to fix this problem?
Honestly, I would recommend replacing the entire Motherboard, unless you can find a trusted repair shop to solder it on.
I damaged the ZIF connector for the battery on my Switch. It works with some pressure and perfect alignment, but I've had issues ever since I damaged it during repairs :/
I'm going to swap it with a functional motherboard, I would advise you do the same.
Hello need a little help. the ribbon cable will not stay connected. and it will not charger. Any thing will help.
