Ce dont vous avez besoin
Identify that the cord being repaired still works, then make sure both ends are unplugged and free to be worked on.
Measure out a piece of heat shrink to be at least 1/2 inch (12.7mm) longer than the damaged length of the cord. Then cut that piece to size.
Slide the cord through the heat shrink to check that the heat shrink covers all of the damaged area.
Keep the heat shrink on the cord but away from the damaged area for the next steps.
Glue Gun Method: Prepare the hot glue gun by plugging it in and allowing it to fully heat up.
Glue Stick Method: Prepare the glue stick by cutting off small pieces to use.
Glue Gun Cont. : Apply hot glue in excess over the damaged area and then slide the heat shrink over that area.
Glue Stick Cont. : Without applying any hot glue, slide the heath shrink over the damaged area of the cord.
Glue Gun Cont. : Completely fill the heat shrink with glue by placing the glue gun nozzle into the opening and fill the remaining space.
Glue Stick Cont. : Fill drop the small pieces of glue stick into the heat shrink. Firmly press the pieces in until they are tightly packed and the heat shrink is full.
When enough glue has been added, apply heat from the lighter or other heat sources onto the heat shrink.
Once the glue cools, you're free to tear off the excess
5 autres ont terminé cette réparation.
