Aller au contenu principal
Reliance Furnace 1910724 Filter Replacement
Ce dont vous avez besoin
  1. Reliance Furnace 1910724  Filter Replacement, Filter: étape 1, image 1 de 1
    • Turn off your furnace to ensure your safety while changing the filter.
  2. Reliance Furnace 1910724  Filter Replacement: étape 2, image 1 de 1
    • The furnace filter usually exists in the blower compartment or in the air duct leading to the blower.
  3. Reliance Furnace 1910724  Filter Replacement: étape 3, image 1 de 1
    • Once you have found the filter placement on your model which is in lower compartment of furnace, remove the old one by sliding it out of the slot or unscrewing the cover.
  4. Reliance Furnace 1910724  Filter Replacement: étape 4, image 1 de 1
    • Dispose of the old filter in a plastic bag to prevent dust and debris from spreading.
  5. Reliance Furnace 1910724  Filter Replacement: étape 5, image 1 de 1
    • Take the new filter and slide it into the slot or attach it to the cover.
    • Make sure the arrows on the filter are pointing in the direction of the air flow. If the filter is not installed correctly, it may not function properly and could damage your furnace.
  6. Reliance Furnace 1910724  Filter Replacement: étape 6, image 1 de 1
    • Set reminder on phone or write on calendar for filter change. Furnace filters should be changed every 1-3 months, depending on usage. Set a reminder for yourself to check and change the filter regularly.
Enjoy the clean air!
Aniqa Ashfaq
Membre depuis le 01/16/23
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team O-2, Woodhouse Winter 2023 Membre de l'équipe York University, Team O-2, Woodhouse Winter 2023
YORK-WOODHOUSE-W23SOG2
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 118
