Changing the furnace filter is a simple and important task that should be done regularly to ensure the proper functioning of your heating system. The manufacturer for Furnace is Reliance and Equipment number 1910724.
Materials needed:
New furnace filter (make sure it is the correct size for your furnace)
Once you have found the filter placement on your model which is in lower compartment of furnace, remove the old one by sliding it out of the slot or unscrewing the cover.
Take the new filter and slide it into the slot or attach it to the cover.
Make sure the arrows on the filter are pointing in the direction of the air flow. If the filter is not installed correctly, it may not function properly and could damage your furnace.
Set reminder on phone or write on calendar for filter change. Furnace filters should be changed every 1-3 months, depending on usage. Set a reminder for yourself to check and change the filter regularly.
