Introduction
The motor controls the blade. If the motor is malfunctioning, the blade will not cut properly.
Ce dont vous avez besoin
Place the device so the back of the product is facing up.
Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
Remove the small clear plastic piece that covers the zoom wheel numbers.
Remove the two 16.0 mm PH00 screws from the front cover.
Use the blue plastic opening tool to pry apart the two halves of the device.
Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
Remove the two 11.0 mm PH00 screws that attach the zoom wheel to the plastic housing.
Remove zoom wheel assembly from housing using fingers.
Remove the small black piece of plastic surrounding the zoom wheel. This will be referred to as the slider.
A pin holds the wheel in place. Using a spudger (preferable metal) and a pair of pliers or tweezers remove the pin to unseat the wheel.
Remove the motor by carefully prying on the back side of the motor with a spudger.
