Aller au contenu principal
Removal/Replacement of Dell Inspiron E1705 Hard Drive
Ce dont vous avez besoin
  1. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Battery: étape 1, image 1 de 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Removal/Replacement of Dell Inspiron E1705 Hard Drive: étape 2, image 1 de 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive: étape 2, image 2 de 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: étape 3, image 1 de 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: étape 3, image 2 de 2
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Removal/Replacement of Dell Inspiron E1705 Hard Drive: étape 4, image 1 de 1
    • Slide the hard drive tray out of the hard drive compartment.
3 autres ont terminé cette réparation.
Malik Shahbal
Membre depuis le 10/05/10
471 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 22-5, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 32
Total : 20,450
