Introduction
This guide shows how to separate the GameCube's optical drive assembly from the motherboard.
Pièces
Aucune pièce spécifiée.
Turn over the Gamecube so that the bottom side is facing up.
Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit.
Do not detach the red and black cooling fan wire from the main unit.(red wire)
