Introduction
We will unscrew the bottom faceplate, then remove the base to access the internal components.
Ce dont vous avez besoin
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
Remove the four 28.07mm Torx #15 screws from the lower case.
9 autres ont terminé cette réparation.
