Aller au contenu principal
Removing Braven BRV-X Bottom Outer Casing
Ce dont vous avez besoin
  1. Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: étape 1, image 1 de 3 Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: étape 1, image 2 de 3 Removing Braven BRV-X Bottom Outer Casing, Bottom Outer Casing: étape 1, image 3 de 3
    • Flip the Braven BRV-X upside down so you are facing the bottom side.
    • With the H1.5 Head Screwdriver, unscrew the four screws.
    • All screws on this device can be stripped easily. Hold your screwdriver with the thumb on top and swivel with the opposite hand's thumb and index finger.
    • Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
    • Gently remove the outer casing, which should reveal the inner shell.
  2. Removing Braven BRV-X Bottom Outer Casing: étape 2, image 1 de 2 Removing Braven BRV-X Bottom Outer Casing: étape 2, image 2 de 2
    • With a Jimmy, cut the two warranty seals on either side.
    • You may also use a tech knife instead of a Jimmy.
    • WARNING: Once warranty seals are broken, you may no longer return the product.
    • Next, remove the 18 screws with a #00 Phillips screwdriver.
  3. Removing Braven BRV-X Bottom Outer Casing: étape 3, image 1 de 2 Removing Braven BRV-X Bottom Outer Casing: étape 3, image 2 de 2
    • Using two plastic opening tools, slide under the cover and slowly lift.
    • There is glue nearly all around the inner shell, so strength will be necessary. When both tools are inserted, you can slide out along the edges.
Courtney Crockett
Membre depuis le 09/29/15
324 Réputation
2 tutoriels rédigés
Équipe
Texas Tech, Team 19-4, Rauch Fall 2015 Membre de l'équipe Texas Tech, Team 19-4, Rauch Fall 2015
TTU-RAUCH-F15S19G4
4 membres
2 tutoriels rédigés
Un commentaire
How do you remove the charging port
Neto - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 14
Total : 1,559
