Aller au contenu principal
Removing Creative Zen Vision W Back Cover
Ce dont vous avez besoin
  1. Removing Creative Zen Vision W Back Cover, Battery Removal: étape 1, image 1 de 3 Removing Creative Zen Vision W Back Cover, Battery Removal: étape 1, image 2 de 3 Removing Creative Zen Vision W Back Cover, Battery Removal: étape 1, image 3 de 3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Removing Creative Zen Vision W Back Cover, Back Cover: étape 2, image 1 de 1
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  3. Removing Creative Zen Vision W Back Cover: étape 3, image 1 de 2 Removing Creative Zen Vision W Back Cover: étape 3, image 2 de 2
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  4. Removing Creative Zen Vision W Back Cover: étape 4, image 1 de 3 Removing Creative Zen Vision W Back Cover: étape 4, image 2 de 3 Removing Creative Zen Vision W Back Cover: étape 4, image 3 de 3
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
Gabriele Pregadio
Membre depuis le 04/17/13
1 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-2, Regan Spring 2013 Membre de l'équipe Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 746
