Aller au contenu principal
Removing Dell Inspiron 1150 Mini Wireless PCI Card
Ce dont vous avez besoin
  1. Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: étape 1, image 1 de 3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: étape 1, image 2 de 3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: étape 1, image 3 de 3
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Wireless MiniPCI Card.
  2. Removing Dell Inspiron 1150 Mini Wireless PCI Card: étape 2, image 1 de 2 Removing Dell Inspiron 1150 Mini Wireless PCI Card: étape 2, image 2 de 2
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  3. Removing Dell Inspiron 1150 Mini Wireless PCI Card: étape 3, image 1 de 1
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
Teja
Membre depuis le 04/27/10
98 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 16-2, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 5,927
