Introduction
Need to get inside the amp? Remove the back panel!
Ce dont vous avez besoin
Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
2 commentaires de tutoriel
I need to know where to find a used circuit board for my Fender Frontman 15G. A circuit board from a Fender Frontman 15R will also work. Please help me.
The way to get the electronics out is by removing the front panel, because removing them through the back is not possible because of the reverb unit. In case you need to disassemble a Fender frontman 15R, have a look at https://www.youtube.com/watch?v=ioQnwjgv...
