Aller au contenu principal
Magellan RoadMate 1200 Back Cover Replacement
Ce dont vous avez besoin
  1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: étape 1, image 1 de 2 Magellan RoadMate 1200 Back Cover Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Back Cover Replacement: étape 2, image 1 de 1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Back Cover Replacement: étape 3, image 1 de 2 Magellan RoadMate 1200 Back Cover Replacement: étape 3, image 2 de 2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Back Cover Replacement: étape 4, image 1 de 2 Magellan RoadMate 1200 Back Cover Replacement: étape 4, image 2 de 2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
2 autres ont terminé cette réparation.
Ross Light
Membre depuis le 04/12/10
217 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 3,467
