Aller au contenu principal
Removing Minolta X-370 Bottom Cover
Ce dont vous avez besoin
  1. Removing Minolta X-370 Bottom Cover, Battery: étape 1, image 1 de 2 Removing Minolta X-370 Bottom Cover, Battery: étape 1, image 2 de 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Bottom Cover: étape 2, image 1 de 1
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Bottom Cover, Bottom Cover: étape 3, image 1 de 2 Removing Minolta X-370 Bottom Cover, Bottom Cover: étape 3, image 2 de 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Bottom Cover: étape 4, image 1 de 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Bottom Cover: étape 5, image 1 de 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
3 autres ont terminé cette réparation.
Nick
Membre depuis le 04/19/11
525 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 8-7, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 membres
9 tutoriels rédigés
Un commentaire
good advice, will use, have multiple Minolta cameras to work with.
gabriel johnson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 46
Total : 11,104
