Aller au contenu principal
Removing Minolta X-370 Lens Holder
Ce dont vous avez besoin
  1. Removing Minolta X-370 Lens Holder, Battery: étape 1, image 1 de 2 Removing Minolta X-370 Lens Holder, Battery: étape 1, image 2 de 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Lens Holder: étape 2, image 1 de 1
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Lens Holder, Bottom Cover: étape 3, image 1 de 2 Removing Minolta X-370 Lens Holder, Bottom Cover: étape 3, image 2 de 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Lens Holder: étape 4, image 1 de 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Lens Holder: étape 5, image 1 de 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  6. Removing Minolta X-370 Lens Holder, Lens Holder: étape 6, image 1 de 3 Removing Minolta X-370 Lens Holder, Lens Holder: étape 6, image 2 de 3 Removing Minolta X-370 Lens Holder, Lens Holder: étape 6, image 3 de 3
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
  7. Removing Minolta X-370 Lens Holder: étape 7, image 1 de 3 Removing Minolta X-370 Lens Holder: étape 7, image 2 de 3 Removing Minolta X-370 Lens Holder: étape 7, image 3 de 3
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  8. Removing Minolta X-370 Lens Holder: étape 8, image 1 de 2 Removing Minolta X-370 Lens Holder: étape 8, image 2 de 2
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  9. Removing Minolta X-370 Lens Holder: étape 9, image 1 de 3 Removing Minolta X-370 Lens Holder: étape 9, image 2 de 3 Removing Minolta X-370 Lens Holder: étape 9, image 3 de 3
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  10. Removing Minolta X-370 Lens Holder: étape 10, image 1 de 2 Removing Minolta X-370 Lens Holder: étape 10, image 2 de 2
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  11. Removing Minolta X-370 Lens Holder: étape 11, image 1 de 2 Removing Minolta X-370 Lens Holder: étape 11, image 2 de 2
    • Remove the left and right plastic covers.
  12. Removing Minolta X-370 Lens Holder: étape 12, image 1 de 3 Removing Minolta X-370 Lens Holder: étape 12, image 2 de 3 Removing Minolta X-370 Lens Holder: étape 12, image 3 de 3
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
4 autres ont terminé cette réparation.
Nick
Membre depuis le 04/19/11
525 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 8-7, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 membres
9 tutoriels rédigés
1 commentaire de tutoriel
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 22
Total : 7,425
