Aller au contenu principal
Introduction
This installation guide will help you remove the rear and front casing of your Nikon Coolpix 4600.
Pièces
Aucune pièce spécifiée.
  1. Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right). Using a Phillips 00 screwdriver, remove all of the six screws.
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  3. Carefully pull the front and back case apart. The front case is attached to internal components and cannot be removed independently.
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  4. Look closely at the connection between the ribbon cable and the motherboard.  Locate the two grey tabs on either side of the connecting bracket.
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
Nathan Sperling
Membre depuis le 08/05/2012
89 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 9-43, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,224
