Aller au contenu principal
Removing Nikon Coolpix 4600 Front and Rear case
Ce dont vous avez besoin
  1. Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: étape 1, image 1 de 2 Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: étape 1, image 2 de 2
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Removing Nikon Coolpix 4600 Front and Rear case: étape 2, image 1 de 2 Removing Nikon Coolpix 4600 Front and Rear case: étape 2, image 2 de 2
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  3. Removing Nikon Coolpix 4600 Front and Rear case: étape 3, image 1 de 1
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
Nathan Sperling
Membre depuis le 05/08/12
119 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 9-43, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 7
Total : 1,481
