Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Removing Nintendo DS Lite Logic Board Screws
Ce dont vous avez besoin
    1. Removing Nintendo DS Lite Logic Board Screws, Nintendo DS Lite Battery Disconnect: étape 1, image 1 de 1
      • Place your device upside down and locate the battery compartment.
      • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
      • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
      • Use only a Phillips screwdriver to remove screw.
      Demander à FixBot
      Ajouter un commentaire
    2. Removing Nintendo DS Lite Logic Board Screws: étape 2, image 1 de 1
      • Slowly remove the battery cover with the iFixit opening tool.
      • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
      Demander à FixBot
    3. Removing Nintendo DS Lite Logic Board Screws: étape 3, image 1 de 2 Removing Nintendo DS Lite Logic Board Screws: étape 3, image 2 de 2
      • Use the iFixit opening tool to carefully pry the battery out of the case.
      • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
      • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
      Demander à FixBot
    1. Removing Nintendo DS Lite Logic Board Screws, Disassembling Nintendo DS Lite Bottom Case: étape 4, image 1 de 1
      • Remove the following seven screws that secure the lower case to the DS Lite:
      • Three silver tri-point screws (5mm long)
      • One black tri-point screw (4mm)
      • Two gold Phillips screws (4mm)
      • One silver Phillips screw (3mm)
      • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
      Demander à FixBot
    2. Removing Nintendo DS Lite Logic Board Screws: étape 5, image 1 de 1
      • On the front edge of the Nintendo DS between the headphone jack plug and volume controls remove the plastic insert (or cartridge) from the lower slot (Slot 2).
      Demander à FixBot
    3. Removing Nintendo DS Lite Logic Board Screws: étape 6, image 1 de 2 Removing Nintendo DS Lite Logic Board Screws: étape 6, image 2 de 2
      • Flip the unit over so that it is facing right-side up.
      • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
      • Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
      Demander à FixBot
    4. Removing Nintendo DS Lite Logic Board Screws: étape 7, image 1 de 3 Removing Nintendo DS Lite Logic Board Screws: étape 7, image 2 de 3 Removing Nintendo DS Lite Logic Board Screws: étape 7, image 3 de 3
      • Carefully separate the two pieces by hand.
      • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
      • When reassembling the cover, make sure that the power and volume switch covers on the bottom case are aligned with the switches on the board to avoid breakage.
      Demander à FixBot
    1. Removing Nintendo DS Lite Logic Board Screws, Logic Board Screws: étape 8, image 1 de 1
      • After taking the bottom case off, remove two Phillips #00 screws that secure the logic board to the plastic case.
      Demander à FixBot
bushing
Membre depuis le 04/23/10
10 502 Réputation
13 tutoriels rédigés
1 commentaire de tutoriel
What size is the screw that fits on the battery cover?
Will York - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 48
30 derniers jours : 247
Total : 22,019
