Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will walk you through step-by-step on how to properly remove and replace the outer shell in the PlayStation 2 Slimline.
Pièces
Aucune pièce spécifiée.
    • Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
  1. Locate the six feet on the bottom of the PS2.
    • Locate the six feet on the bottom of the PS2.
    • Five of the feet are in plain sight and one of the feet is located under the black void sticker on the bottom of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or even the screw should be in plain sight.
  2. Pry apart the five visible feet from the bottom of the device using a spudger,  or your fingers. Pry apart the five visible feet from the bottom of the device using a spudger,  or your fingers. Pry apart the five visible feet from the bottom of the device using a spudger,  or your fingers.
    • Pry apart the five visible feet from the bottom of the device using a spudger, or your fingers.
  3. The sixth foot is located under the black VOID sticker.  Remove the sticker before  removing the foot underneath. The sixth foot is located under the black VOID sticker.  Remove the sticker before  removing the foot underneath.
    • The sixth foot is located under the black VOID sticker. Remove the sticker before removing the foot underneath.
  4. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves. Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves. Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves.
    • Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves.
  6. If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
7 autre(s) ont terminé cette réparation.
Jared Hirata
Membre depuis le 09/04/2013
600 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 17-4, Regan Spring 2013 Membre de l'équipe Cal Poly, Team 17-4, Regan Spring 2013
CPSU-REGAN-S13S17G4
3 membres
14 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 2,384
