Aller au contenu principal
Removing PowerMac G4 M5183 DVD-ROM Drive Tray
Ce dont vous avez besoin
  1. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: étape 1, image 1 de 2 Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: étape 1, image 2 de 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: étape 2, image 1 de 2 Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: étape 2, image 2 de 2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: étape 3, image 1 de 1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: étape 4, image 1 de 3 Removing PowerMac G4 M5183 DVD-ROM Drive Tray: étape 4, image 2 de 3 Removing PowerMac G4 M5183 DVD-ROM Drive Tray: étape 4, image 3 de 3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
Ligne d'arrivée
26 autres ont terminé cette réparation.
Justin Petrilli
Membre depuis le 01/21/10
3 114 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 13-24, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 membres
25 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 10,601
