Introduction
If you have to repair inner components you first must open the top cover.
Ce dont vous avez besoin
Remove all attachments such as drawers, water tank, brewing unit.
Carefully pull the steam button out. If it is too tight, first loosen the cover (steps 2 to 4), lift slightly and then push the ratchet nose with a small screwdriver.
Remove the single T10 Torx screw on the rear edge of the top cover under the water reservoir.
Remove the single Phillipps screw on the rear edge of the top cover under the container of the coffee beans.
There are two Phillipps screws on the frontal unterside edge of the top cover. Turn them out.
Merci à ces traducteurs :
100%
VauWeh nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
