Aller au contenu principal
Removing Samsung DVD-P230 Motherboard
Ce dont vous avez besoin
  1. Removing Samsung DVD-P230 Motherboard, Outer Cover & Faceplate: étape 1, image 1 de 3 Removing Samsung DVD-P230 Motherboard, Outer Cover & Faceplate: étape 1, image 2 de 3 Removing Samsung DVD-P230 Motherboard, Outer Cover & Faceplate: étape 1, image 3 de 3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Removing Samsung DVD-P230 Motherboard: étape 2, image 1 de 1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Removing Samsung DVD-P230 Motherboard: étape 3, image 1 de 1
    • Unscrew the 3 screws in the back.
  4. Removing Samsung DVD-P230 Motherboard: étape 4, image 1 de 2 Removing Samsung DVD-P230 Motherboard: étape 4, image 2 de 2
    • Pull the outer case upward and then towards you.
  5. Removing Samsung DVD-P230 Motherboard: étape 5, image 1 de 3 Removing Samsung DVD-P230 Motherboard: étape 5, image 2 de 3 Removing Samsung DVD-P230 Motherboard: étape 5, image 3 de 3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Removing Samsung DVD-P230 Motherboard: étape 6, image 1 de 2 Removing Samsung DVD-P230 Motherboard: étape 6, image 2 de 2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Removing Samsung DVD-P230 Motherboard, Power Cord: étape 7, image 1 de 3 Removing Samsung DVD-P230 Motherboard, Power Cord: étape 7, image 2 de 3 Removing Samsung DVD-P230 Motherboard, Power Cord: étape 7, image 3 de 3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Removing Samsung DVD-P230 Motherboard, Tray: étape 8, image 1 de 3 Removing Samsung DVD-P230 Motherboard, Tray: étape 8, image 2 de 3 Removing Samsung DVD-P230 Motherboard, Tray: étape 8, image 3 de 3
    • Remove the three screws holding in the DVD tray
  9. Removing Samsung DVD-P230 Motherboard: étape 9, image 1 de 2 Removing Samsung DVD-P230 Motherboard: étape 9, image 2 de 2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Removing Samsung DVD-P230 Motherboard: étape 10, image 1 de 2 Removing Samsung DVD-P230 Motherboard: étape 10, image 2 de 2
    • Gently lift the DVD tray off of the motherboard.
  11. Removing Samsung DVD-P230 Motherboard, Motherboard: étape 11, image 1 de 2 Removing Samsung DVD-P230 Motherboard, Motherboard: étape 11, image 2 de 2
    • Unscrew the 2 screws on the motherboard
    • Unscrew the 2 screws on the back
  12. Removing Samsung DVD-P230 Motherboard: étape 12, image 1 de 3 Removing Samsung DVD-P230 Motherboard: étape 12, image 2 de 3 Removing Samsung DVD-P230 Motherboard: étape 12, image 3 de 3
    • Disconnect the wires and ribbon by pulling them out of their respective connections
  13. Removing Samsung DVD-P230 Motherboard: étape 13, image 1 de 2 Removing Samsung DVD-P230 Motherboard: étape 13, image 2 de 2
    • Lift board up and out of the lower case
Mitchell Hart
Membre depuis le 01/21/11
903 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 3-30, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 3,220
