Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Removing factory feet from a Mac Laptop (Non-Retina)
Ce dont vous avez besoin
    1. Removing factory feet from a Mac Laptop (Non-Retina), Change note: étape 1, image 1 de 2 Removing factory feet from a Mac Laptop (Non-Retina), Change note: étape 1, image 2 de 2
      Outil utilisé dans cette étape :
      Essential Electronics Toolkit
      $29.95
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      Demander à FixBot
      Ajouter un commentaire
    1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: étape 2, image 1 de 2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: étape 2, image 2 de 2
      • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
      • If possible, disconnect the battery to protect your components once the bottom is removed.
      • Remove the bottom cover of your MacBook with the guide for your specific system.
      Demander à FixBot
    2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: étape 3, image 1 de 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: étape 3, image 2 de 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: étape 3, image 3 de 3
      • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
      • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
      Demander à FixBot
    3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: étape 4, image 1 de 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: étape 4, image 2 de 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: étape 4, image 3 de 3
      iFixit Opening Picks (Set of 6)
      $4.95
      • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
      • After removing the inner plug, push the foot out with a spudger or screwdriver.
      Demander à FixBot
    4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: étape 5, image 1 de 2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: étape 5, image 2 de 2
      Adhesive Cleanup Kit (Set of 12)
      $7.99
      • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
      • After removing the old feet, install the new set onto the bottom cover.
      • Re-install the cover on the computer.
      Demander à FixBot
Ligne d'arrivée
5 autres ont terminé cette réparation.
Nick
Membre depuis le 11/10/09
105 503 Réputation
72 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
334 membres
5 539 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 86
Total : 6,662
