Aller au contenu principal
Removing the Apple Cinema Display M8149 Display Hinge
Ce dont vous avez besoin
  1. Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: étape 1, image 1 de 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: étape 1, image 2 de 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: étape 1, image 3 de 3
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Removing the Apple Cinema Display M8149 Display Hinge: étape 2, image 1 de 3 Removing the Apple Cinema Display M8149 Display Hinge: étape 2, image 2 de 3 Removing the Apple Cinema Display M8149 Display Hinge: étape 2, image 3 de 3
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Removing the Apple Cinema Display M8149 Display Hinge: étape 3, image 1 de 2 Removing the Apple Cinema Display M8149 Display Hinge: étape 3, image 2 de 2
    • Remove the Apple Display Connector plate screws (9.52 x 3.43 mm) with the PH 2 screwdriver.
    • Once the two screws have been removed, move the cord out of the way.
  4. Removing the Apple Cinema Display M8149 Display Hinge: étape 4, image 1 de 3 Removing the Apple Cinema Display M8149 Display Hinge: étape 4, image 2 de 3 Removing the Apple Cinema Display M8149 Display Hinge: étape 4, image 3 de 3
    • Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
    • Then lift out the hinge mount.
3 autres ont terminé cette réparation.
Thomas Harper
Membre depuis le 04/01/11
244 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-41, Forte Spring 2011 Membre de l'équipe Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 membres
12 tutoriels rédigés
Un commentaire
in 2023 where can I get a replacement stand?
Mitch Leung - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 25
Total : 7,779
