Aller au contenu principal
Removing the HP Compaq dx2000MT Optical (CD) Drive
Ce dont vous avez besoin
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: étape 1, image 1 de 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 2, image 1 de 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 2, image 2 de 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 3, image 1 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 3, image 2 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 3, image 3 de 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 4, image 1 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 4, image 2 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 4, image 3 de 3
    • Once again, this may take considerable force.
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: étape 5, image 1 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: étape 5, image 2 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: étape 5, image 3 de 3
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 6, image 1 de 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 6, image 2 de 2
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 7, image 1 de 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 7, image 2 de 2
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 8, image 1 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 8, image 2 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: étape 8, image 3 de 3
    • Remove the optical drive by sliding it out the front of the device.
Logan Pace
Membre depuis le 10/12/11
2 251 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 17-16, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 membres
17 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 1,501
