Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide shows how to remove the laptop HDD
Pièces
Aucune pièce spécifiée.
  1. Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  3. With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed. Lift the left side of the bay cover and swing it up and to the right to remove it. Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed.
    • Lift the left side of the bay cover and swing it up and to the right to remove it.
    • Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • Grasp the plastic tab and slide the hard drive to the right to disconnect it from the motherboard.
    • Lift the hard drive straight up and out of the laptop.
  4. To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive. To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
    • To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
14 autre(s) ont terminé cette réparation.
Richdave
Membre depuis le 09/04/2010
30 194 Réputation
30 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
293 membres
929 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 13
7 derniers jours : 13
30 derniers jours : 61
Total : 7,815
