Outils
Pièces
Aucune pièce spécifiée.
Using a Philips driver remove the 18 screws from the rear panel.
Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
Remove the 7 connectors from the board
Remove the 7 screws from the board
Lift the main board away from the chassis ensuring you don's snag or catch any of the cables.
15 autre(s) ont terminé cette réparation.
Un commentaire
Ma télé LCD Samsung ne veule pas s allume pas de courant que dois je faire s.v.p
