Aller au contenu principal
Remplacement Circuit NFC Nexus 5
Ce dont vous avez besoin
  1. Remplacement Circuit NFC Nexus 5, Coque arrière: étape 1, image 1 de 3 Remplacement Circuit NFC Nexus 5, Coque arrière: étape 1, image 2 de 3 Remplacement Circuit NFC Nexus 5, Coque arrière: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    iFixit Opening Picks (Set of 6)
    J'achète
    • Utilisez un outil d'ouverture en plastique pour ouvrir les clips sur le dessus et sur chaque côté de la coque arrière.
    • Le bas est fixé avec un peu d'adhésif. Vous devriez finalement pouvoir retirer la coque arrière en utilisant un médiator.
    • Il vaut mieux éviter de faire levier autour de la fente de la carte SIM. En effet, le plastique est très fin et risque de se casser si vous prenez appui dessus.
    Wireless QI and NFC.
    Once I have put everything together with the new battery in place, I have as last replaced the plastic back cover, snapping all the clips back around the edges of the phone. Alas, I was quick to realise the QI Wireless charging has ceased to work.
    I almost blamed the battery, or worse, me.
    QUICK TIP: there is actually another clip in the middle of the plastic back cover - just press with your thumb just above the 'S' in NEXUS emblem and, voila! Snaps back in.
    Wireless charge and NFC - works, once again.
    cwioro - Réponse
    you just saved me like 30 bucks. thank you so much.
    Robert Nolan -
    + 1, had the same issue and pressing just near the S fixed it! Thanks a lot!
    nicco82 -
    Just a me too, I had to press above the S and it was quite a snap
    Erik Karlin -
    There seems to be two contacts that snap into place. One is in line with the led pretty much in the middle of the phone and the second one in line with the camera lens on the opposite side to the lens. The middle one for me snapped pretty lightly, but the side one required a bit more pressure. After that the nfc started working again. Thanks for posting this!
    Dennis Millner -
    Is it hard to remove the battery door? Worried I might damage it.
    Ash - Réponse
    When I openend the back cover I damaged two clips. One about 2.5cm (1 inch) below the volume controls and one on the other side about same height. The cover fits good without those two but on one side there is a small gap where the clip broke. But I have a hard cover protector on my phone so it's not that bad.
    simonlwheeler - Réponse
    The case around the sim slot is pretty thin and easy to break, best to avoid using the pry tool at this point.
    Aled Morris - Réponse
    Excellent tip, should be included in the main guide.
    fprades - Réponse
    Hey Author, i need to ur expert advice...i replaced my nexus 5's back cover. since the new one did not have the vibrators battery i had to take it from the old one and connect it to the new one...on removing i noticed that it was stuck to the cover by a glue
    Question: what glue to use to hold the battery to the cover?
    suwaid akbar - Réponse
    Any adhesive will do. I used a hot glue gun. You shouldn't need expert advice to figure that out. Use your head.
    tjt263 -
    The case around the volume control is also pretty thin.... I broke mine prying so avoid the pry there too.
    Also my back had glue at the bottom and I haven't seen mentioned
    kornerson - Réponse
  2. Remplacement Circuit NFC Nexus 5, Châssis: étape 2, image 1 de 1
    • Retirez les six vis cruciformes #00 de 4 mm qui fixent le châssis au téléphone.
    • Si vous souhaitez remplacer l'écran LCD et la vitre tactile, retirez également les quatre vis de 4 mm du cache de la carte fille, avec le même tournevis.
    I had a bit more success with the Phillips #000.
    Ross Light - Réponse
    Step 4 (removing the screws in the protecting plate) needs to happen before Step 2 ( removing the connectors)
    Esteban Valles - Réponse
    These were Y0 screws for me.
    Benjamin Hollway - Réponse
    Same here, Benjamin
    Ítalo Masserano -
    Me three on the Y-type screw heads.
    Jamoross -
    Same for me. I had more luck with the two screws in the middle with #000.
    Rewarp - Réponse
  3. Remplacement Circuit NFC Nexus 5: étape 3, image 1 de 2 Remplacement Circuit NFC Nexus 5: étape 3, image 2 de 2
    • Retirez le châssis du téléphone.
    There's also some adhesive holding the motherboard cover plate in place, below the camera. Has to be pulled a little stronger than expected.
    tkatona - Réponse
  4. Remplacement Circuit NFC Nexus 5, Batterie: étape 4, image 1 de 2 Remplacement Circuit NFC Nexus 5, Batterie: étape 4, image 2 de 2
    • Servez-vous de l'extrémité plate d'une spatule (spudger) pour débrancher le connecteur de la batterie.
  5. Remplacement Circuit NFC Nexus 5, Circuit NFC: étape 5, image 1 de 1
    • Déconnectez le connecteur de la carte mère en utilisant un plastic opening tool.
  6. Remplacement Circuit NFC Nexus 5: étape 6, image 1 de 1
    • Tirez doucement sur le connecteur jusqu'à ce que le circuit NFC commence à s'enlever. Cela dévoilera un pli dans le circuit NFC qui est commun.
Pour remonter votre appareil, suivez ce guide en sens inverse.
13 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
CynEquanon nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Chris Willis
Membre depuis le 10/03/14
1 371 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 13-4, Staggers Fall 2014 Membre de l'équipe USF Tampa, Team 13-4, Staggers Fall 2014
USFT-STAGGERS-F14S13G4
3 membres
13 tutoriels rédigés
2 commentaires
There seems to be a few revisions of the NFC board
My original has the part number EAX65371601_1.1
The replacement parts I received were EAX65371601_E and EAX65371601_1.1. Neither of which work. The NFC slider will not stay in the ON position. Looking at the logcat show some cryptic errors.
Has anyone had any success in replacing the NFC board, if so what version was the original and the replacement?
Paul H - Réponse
My NFC slider under Settings, Wireless & networks, More… also won’t stay. The phone has taken some abuse, so not surprised if something’s awry. BUT wireless (Qi) charging does work … I wonder if the NFC Board connector carries both of these, so if NFC is bad, but Qi charging is good, it’s not the board…? Anyone troubleshot and fixed these same symptoms?
David Spalding - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 14,438
