Aller au contenu principal
Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009
Ce dont vous avez besoin
  1. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009, Retirer les vis du boîtier inférieur: étape 1, image 1 de 1
    • Retirez les 10 vis suivantes par lesquelles est fixé le boîtier inférieur du MacBook Pro 13" Unibody :
    • Sept vis Phillips 3 mm.
    • Trois vis Phillips 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Réponse
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Réponse
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Réponse
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Réponse
  2. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009, Soulever le boîtier inférieur: étape 2, image 1 de 1
    • Soulevez légèrement le boîtier inférieur et poussez-le vers l'arrière de l'ordinateur afin de désengager les pattes de fixation.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Réponse
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Réponse
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009, Batterie: étape 3, image 1 de 1
    • À titre de précaution, nous vous conseillons de débrancher le connecteur de la batterie de la carte mère afin d'éviter les décharges électriques.
    • À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
    Citation de gansodesoya :
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Réponse
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Réponse
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Réponse
  4. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009, Écran complet: étape 4, image 1 de 3 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009, Écran complet: étape 4, image 2 de 3 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009, Écran complet: étape 4, image 3 de 3
    • Avec l'extrémité plate d'une spatule (spudger), soulevez le connecteur de la nappe du caisson de basse/du haut-parleur droit pour le débrancher de sa prise sur la carte mère.
    • Veillez à faire levier sous le connecteur comme sur la photo et non pas sous la prise même. Sinon, vous risqueriez de séparer accidentellement la prise de la carte mère.
    Please Be Carefully With This Step, Because I Had To Resolder It Back To The Logic Board. But There Is A Black Foam Piece Over The Cable You Have To Pry Up, Lift The Foam Piece And Then Try To CAREFULLY Pry Cable Connector
    BWilliams842 - Réponse
  5. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 5, image 1 de 1
    • Déconnectez la nappe de la caméra en tirant l'extrémité mâle tout droit hors de la prise.
    • Une petite pièce en plastique dur est fixée sur la carte mère pour empêcher la nappe de la caméra de sortir de sa prise. Veillez à l'enlever d'abord sinon vous pourriez endommager les connecteurs.
    • Faites attention à tirer sur le connecteur parallèlement à la surface de la carte mère, vers le lecteur optique et non vers le haut.
    Be careful to the piece of plastic that prevents camera cable failing out its socket! Do not force connector! Look at plastic before attempting to remove connector Plastic is partially covered by cdrom flat connector at right of camera cable connector
    Silvio - Réponse
    This step is unnecessarily tricky. I’ve tried to make it better by adding images highlighting the plastic stopper thingy and showing a clear arrow of the direction the cable should be pulled.
    However, simply pulling the cable may not be enough to remove it. It sure wasn’t for me. I think there ought to be a close-up of the two little nubbins on the sides of the plug which one uses to wiggle it loose from the connector by gently prying with a tiny flathead screwdriver. I didn’t add that tip because (a) it would have made the instructions longer, (b) I didn’t think to take a photo of it, and (c) using a screwdriver carelessly next to the logic board could scratch or break components on the motherboard. A guitar pick or very small spudger might work.
    hackerb9 - Réponse
    @hackerb9 Thanks for your edits and comments! I took some additional shots and tried to clean this up a little for everyone. There should be a lot less confusion now. Interestingly, neither of the two MacBook Pros used for these guides had the plastic retainer piece you folks mentioned, but I left that image in a link so everyone can still see what it looks like if needed.
    Jeff Suovanen -
    Thanks for incorporating some of my edits and for taking new photos.
    Are you the one who took the original photographs? If so, you did originally have the hard plastic retainer as it was in those photos, just obscured by your thumbnail. The glue on the retainer allows it to shift a bit, so it's possible you took out the cable and knocked off the retainer without noticing it.
    Your two frame animation of pulling out the plug is helpful to show the proper direction. Given the number of people who have destroyed their MacBooks from this procedure, I think we should do even better. The instruction would be clearer if it said, “Disconnect the camera cable by sliding it horizontally out of its socket.”
    Also, if you can post a link to a picture without fingers in the shot, I will add an arrow showing the proper direction. (I would have added it to the original, but visually it would have gone through your fingers.)
    hackerb9 - Réponse
    P.s. this isn't as important, but where did you hear the tip about the hairdryer? I'd leave that out as firmly peeling it up works fine.
    hackerb9 -
    Negative, I’m not the original photographer. You’re right, I do see the retainer in some of the previous photos, although it wasn’t in any of the images for this particular step. May have been an oversight on the part of the original author! So I’m glad you caught it. I updated the verbiage as you requested. Don’t worry about adding arrows—at this point, if someone ignores both the images and the multiple warnings in the text, that’s no longer a fault with the guide. The heat/hairdryer tip is standard practice for anything that’s secured with adhesive—I hardly ever work on a MacBook of any vintage without using a heat gun at least a couple times. It may not be strictly necessary, but the result is much cleaner and it reduces the risk of accident.
    Jeff Suovanen -
  6. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 6, image 1 de 1
    • Dégagez le câble de données de la caméra de la rainure dans le lecteur optique.
  7. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 7, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 7, image 2 de 2
    • Dévissez les vis suivantes, fixant le câble de données de la caméra et le haut-parleur droit au boîtier supérieur :
    • Deux vis cruciformes de 8 mm.
    • Une vis cruciforme de 4 mm.
    • Une des vis cruciformes de 8 mm risque de rester prise dans boucle de la mise à terre du câble de la caméra.
    • Faites glisser la fixation du câble de la caméra hors de son emplacement sous le caisson de basse et ôtez-la de l'ordinateur.
  8. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 8, image 1 de 3 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 8, image 2 de 3 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 8, image 3 de 3
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et pivotez-la vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    • Tirez le connecteur du câble de données de l'écran tout droit hors de sa prise.
    • Veillez à tirer le connecteur hors de sa prise et non vers le haut.
    Well, my display ended up looking like this after the repair:
    http://i1106.photobucket.com/albums/h366...
    As you can see, there was a light/dark banded pattern along the bottom of the screen, corresponding to the LCD's backlight. In my case it was also accompanied by a constant high pitched whistling noise. I swear to anything that's holy, it was not coming from the fan or the speaker, but rather the motherboard itself.
    Anyway, both these problems went away when I disconnected and reconnected the connector at this stage. I'm saying this on the off chance it helps someone else.
    Jonty Levine - Réponse
    It's not to clear but there is a piece of spring steel that rotates away from the main (circuit board side) of the connector....this piece sort of hugs the parameter of the screen cable locking it to the circuit board...both arms wrapped around your brother....looking closely (10x magnifier) at this cable one of the gold connections is slightly oxidized---my display arbitrarily flickers and this symptom is lessened as the temperature increases...I suspect this is the cuase of the screen flashing on/off
    brian62 - Réponse
  9. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 9, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 9, image 2 de 2
    • Dévissez les deux vis suivantes, fixant le support du câble de données de l'écran au boîtier supérieur :
    • Une vis cruciforme de 7 mm.
    • Une vis cruciforme de 5 mm.
    • Ôtez le support du câble de données de l'écran du boîtier supérieur.
  10. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 10, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 10, image 2 de 2
    • Dévissez les deux vis extérieures Torx de 6,5 mm fixant les deux supports de l'écran au boîtier supérieur (4 vis au total).
    Hey folks, regarding the screw/driver sizes: there are separate guides for the Mid 2010 model with the T8 screws. Always use the correct guide for your model to avoid confusion, stripped screws, etc. Hope this helps!
    Jeff Suovanen - Réponse
  11. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 11, image 1 de 1
    • Ouvrez votre MacBook de sorte que l'écran est perpendiculaire au boîtier supérieur.
    • Posez votre MacBook ouvert sur une table comme sur la photo.
    • Pendant que vous maintenez l'écran et le boîtier supérieur d'une main, dévissez la vis Torx de 6,5 mm restante du support inférieur de l'écran.
  12. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 12, image 1 de 1
    • Veillez à maintenir l'écran et le boîtier supérieur ensemble avec votre main gauche. Si vous les lâchez, vous risquez de faire tomber l'écran/ le boîtier inférieur libéré et donc de les abîmer.
    • Dévissez la dernière vis Torx T6 de 6 mm fixant l'écran au boîtier supérieur.
    Removing the screen assembly this way, with the computer standing on edge, is needlessly risky and difficult. By the 5th or 6th time I did this procedure (of perhaps a hundred), it dawned on me that there’s a way, way easier method for the whole lid removal job: 1. After removing the bottom cover and disconnecting power, hang the open laptop, keyboard down, facing away, over the edge of your work table with the lid assembly hanging down, monitor facing toward the table and pushed against the table edge. (If you’re klutzy, tape the main body to the table so it can’t slide around.) 2. With the unit positioned this way, you can easily disconnect the various cables & remove the 6 hinge screws. Now the lid assembly will just be hanging, easy to lift away from the main body without difficulty or danger. 3. Reverse this to put it back together.
    clinton - Réponse
    Nice tip, Clinton! I’ll have to try that next time. Do you have photos of how it is done so this guide can be updated?
    hackerb9 -
  13. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 13, image 1 de 2 Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 13, image 2 de 2
    • Saisissez le boîtier supérieur de votre main droite et faites-le légèrement pivoter vers le haut de l'écran de sorte que le support supérieure de l'écran s'éloigne du bord du boîtier supérieur.
    • Faites pivoter et éloignez légèrement l'écran du boîtier supérieur.
  14. Remplacement de l'écran complet du MacBook Pro 13" Unibody mi-2009: étape 14, image 1 de 1
    • Soulevez et éloignez l'écran du boîtier supérieur en veillant à ce qu'aucun support ni aucune nappe ne reste accroché.
    Re-assembly hint: Laying the base, keyboard down, on a table top with the hinge side over the edge about 1/2" toward you is a more stable position for re-assembly than trying to do this up on its edge. This has the added benefit of being able to reinsert the torn screws vertically.
    Pete H - Réponse
    May be in the wrong place but then please direct me. At this step, can I just take off the upper half (meaning the screen, LCD, and top housing shell in one) and simply replace it with another upper half of the same edition???
    cmackay13stmarys - Réponse
    Yes, you can. Thanks what I'm doing now. :)
    Mike Mayaka -
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
63 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
73%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Un commentaire
Does the same apply to the 2009 and 2010 15”?
IFCJW - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 33
30 derniers jours : 90
Total : 93,251
