Aller au contenu principal
Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009
Ce dont vous avez besoin
  1. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009, Trappe d'accès: étape 1, image 1 de 2 Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009, Trappe d'accès: étape 1, image 2 de 2
    • Boîtier fermé, placez l'Unibody à l'envers sur une surface plane.
    • Appuyez sur le côté rainuré du loquet de déverrouillage de la trappe d'accès de manière à saisir l'extrémité libre du loquet. Soulevez le loquet de déverrouillage à la verticale.
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - Réponse
    Citation de aguib :
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - Réponse
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - Réponse
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - Réponse
    On other guides you state the height of the HD that can be supported, e.g. Remplacement du disque dur du MacBook Pro 15" Core 2 Duo modèle A1211 , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - Réponse
    Citation de SHerwood Ball :
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - Réponse
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - Réponse
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - Réponse
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - Réponse
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - Réponse
  2. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 2, image 1 de 1
    • La trappe d'accès est à présent suffisamment relevée pour la basculer et la retirer de l'Unibody.
  3. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009, Batterie: étape 3, image 1 de 1
    • Assurez-vous que la languette de la trappe d'accès est bien à la verticale avant de commencer.
    • Tirez sur la languette et retirez la batterie de votre MacBook.
    • Si la languette n'est pas bien positionnée, elle empêchera la batterie de sortir.
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - Réponse
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - Réponse
  4. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009, Boîtier inférieur: étape 4, image 1 de 1
    • Retirez les huit vis suivantes par lesquelles le boîtier inférieur est fixé au châssis :
    • Une vis Phillips 5,4 mm.
    • Trois vis Phillips 14 mm.
    • Quatre vis Phillips 3,5 mm.
    Hi, My name is Jess I need help asap I accidentally dropped my macbook Pro and i cant find the silver screw for the top left back side, Does any one know if I can replace it with an eye glass screw?? If you can help at all Please e-mail me at Chambliss_jess@yahoo.com thx please help me my bf is going off... ;(
    Jess - Réponse
    The fixit PH00 is the wrong screw driver for this entire job. It did not fit in the screws, it was too pointy and caused screws to be rounded off.
    mattrittgers - Réponse
  5. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 5, image 1 de 1
    • En vous servant des deux mains, soulevez le boîtier inférieur et retirez-le du boîtier supérieur.
    About midway along each edge is a snap. To release each snap, gently slide the flat edge of a Spudger under the lower case, then lift the lower case away.
    jonathansturges - Réponse
  6. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009, Écran complet: étape 6, image 1 de 2 Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009, Écran complet: étape 6, image 2 de 2
    • Si nécessaire, décollez du connecteur de la nappe de la caméra le joint d'étanchéité EMI (contre les interférences électromagnétiques).
    • Déconnectez la nappe de la caméra en tirant l'extrémité mâle tout droit hors de sa prise, vers l'ouverture du lecteur optique.
    • N'essayez pas de tirer tout droit sur le connecteur pour le débrancher de la carte. Tirez-le parallèlement à la surface de la carte mère.
    • Dégagez le câble de données de l'écran de la rainure sur le lecteur optique.
    I have a problem with previous made unprofessional teardown of this mac, and the port that the camera cable is connected to, on the m-board, is cracked, because somebody pulled it straight up .. can someone please, share an idea about the way of fixing it, or maybe a name of the part i need ?
    sanchoser - Réponse
  7. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 7, image 1 de 2 Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 7, image 2 de 2
    • Dévissez les deux vis cruciformes fixant le support de la nappe de la caméra au boîtier supérieur.
    • La vis la plus à gauche pourrait rester prise dans la nappe de la caméra.
    • Séparez le support de la nappe de la caméra et la nappe de la caméra et ôtez-le de l'ordinateur.
    For reassembly, it would improve the instructions to note the exact orientation of the camera cable, as well as the LVDS cable, in these steps (7-10). This avoids confusion as to where those cables go when the display is reattached (working steps 11-13 in reverse).
    As viewed from the orientation of the laptop at this point (looking into the motherboard from the underside), these cables are routed ABOVE the mounting plates for the hinges.
    Viewed from the front of the machine (as it would be sitting on the desk in front of you during normal use), they are routed BELOW those plates.
    Haitham - Réponse
    On the 13” there’s an additional screw securing the camera cable bracket to the speaker chamber thing. You have to then gently lift up on the speaker chamber corner.
    dgdeckert - Réponse
  8. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 8, image 1 de 2 Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 8, image 2 de 2
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble LVDS et faites-la pivoter vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    • Tirez le connecteur LVDS tout droit hors de sa prise.
    • Lorsque vous déconnectez le câble LVDS, ne tirez pas sur la languette noire fixée au dispositif de verrouillage du câble LVDS. Nous vous recommandons de remuer le câble de gauche à droite pendant que vous exercez de la pression pour faire "sortir" lentement le connecteur de sa prise.
  9. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 9, image 1 de 2 Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 9, image 2 de 2
    • Dévissez la vis cruciforme de 7 mm du support du câble LVDS.
    • Cette vis pourrait rester prise dans le câble LVDS.
    • Ôtez le support du câble LVDS du boîtier supérieur.
    On the 13” there are TWO screws securing the LVDS cable bracket, of different lengths.
    dgdeckert - Réponse
  10. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 10, image 1 de 1
    • Dévissez les deux vis extérieures Torx de 6 mm fixant de chaque côté l'écran au boîtier supérieur (quatre vis au total).
    Ccouldn't make it past step 10 as the two T6 screws on the right stripped. I was using the correct tool, correctly seated, but the screws were simply unwilling to turn and the screw head gave out before they turned at all. The ones on the left came out alright, but there seems to be some type of thread glue on them. Recommendations on how to break that seal without stripping the screw heads might be a good idea. Otherwise - be forewarned.
    Jonathan Field - Réponse
    I have the same problem with step 10. Can't remove the screw on the left, it is all damaged.
    Benny Chew - Réponse
  11. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 11, image 1 de 1
    • Ouvrez votre MacBook de sorte que l'écran est perpendiculaire au boîtier supérieur.
    • Posez votre MacBook ouvert sur une table comme sur la photo.
    • Pendant que vous maintenez l'écran et le boîtier supérieur d'une main, dévissez la vis Torx de 6 mm restante de la fixation inférieure de l'écran.
    Unlock without removing them , the two remaining center 6mm Torx screws securing the display to the upper case.
    thierry28722 - Réponse
  12. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 12, image 1 de 1
    • Veillez à maintenir l'écran et le boîtier supérieur avec votre main gauche. Si vous les lâchez, vous risquez de faire tomber l'écran ou le boîtier inférieur et donc de les abîmer.
    • Dévissez la dernière vis Torx T6 de 6 mm fixant l'écran au boîtier supérieur.
    One of the Torx screws holding the Display in place failed to come out. I tried too hard and it shredded the head of the screw so there was no physical leverage to the screw driver, so I left it to avoid any further damage.
    So instead I removed ‘not’the torx screw on the computer but the one on the display itself. There are three on the inner part of the screen, two facing the display and the third on the other side. It sled out easily.
    It only added a couple of minutes to my time removing it.
    But a word of caution, you must remove the long plastic housing that holds the cables for the iSight and display, just be gentle and slide it off trying not to snag the cables, it should come off easy.
    cngdoon - Réponse
  13. Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 13, image 1 de 3 Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 13, image 2 de 3 Remplacement de l'écran complet des MacBook Pro 15" Unibody fin 2008 et début 2009: étape 13, image 3 de 3
    • Saisissez le boîtier supérieur de votre main droite et faites-le légèrement pivoter vers le haut de l'écran de sorte que la fixation supérieure de l'écran s'éloigne du bord du boîtier supérieur.
    • Faites pivoter et éloignez légèrement l'écran du boîtier supérieur.
    • Soulevez et éloignez l'écran du boîtier supérieur en veillant à ce que aucune fixation ni aucune nappe ne reste accrochée.
    If I purchase a MBP 15' for parts that has a good top case, LCD and Glass, could I stop at Step 14, replace the entire top case and reverse from Step 13 to put it back together? Or do I need to proceed with steps 14 to 21, loosening the glue, lifting the glass, replacing the LCD?
    jbarrick1 - Réponse
    I think you should be good up to just Step 14 if that's the case.
    craig - Réponse
    On the 13” just slightly open the display/lid a little more and it’ll fall away without needing to do any of the push forward/away stuff as depicted on the 15” here.
    dgdeckert - Réponse
Pour remonter votre ordinateur, suivez ces instructions en sens inverse.
61 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
6 commentaires
Just repaired my Macbook Pro using this guide! Kudos for writing such easy to follow guides complete with pictures!
Great website.. Keep up the great work!
krkarl - Réponse
I used this guide to replace my hinges, but I noticed that the real problem was that the display was separating from the case. I Googled it and found a few reports like (https://discussions.apple.com/thread/371...) indicating that Apple has a replacement program in place addressing this as a latent defect.
I took my machine to the local Apple store, and even though I bought it at the end of 2008, they replaced the display for free.
If you're having a display separation issue it's worth seeing what Apple says before digging into it.
Marty Picco - Réponse
This thread is now "not authorized" for viewing. I think Apple doesn't want anyone to know about this issue!
pmpanache -
This is a great guide. I also read the guide pertaining to the 2.53 GHz Mid-2009 MacBook Pro Display Assembly.
I wanted to report that I successfully removed the display assembly from a Mid-2009 MacBook Pro (2.53 GHz - no discrete graphics) and installed it on the Late-2008 MacBook Pro (2.53 GHz with dual graphics).
Everything appears to be identical, except (strangely) the screws, that are generally captive in the camera cable and the LVDS cable, need to stay with their original MacBook Pro. Meaning, keep all the screws with the same MacBook Pro. The other screws did appear to be identical though.
Bottom line, keep the screws to the same MacBook. That's easy enough, just remove the captive screws from the cables to keep them with the same MacBook Pro they were from.
(Also, the camera cable where it attaches the logic board was slightly closer to the optical drive and seemed to overlap it slightly when transferring the Mid-2009 display to the Late-2008 MacBook Pro. This didn't seem to pose a problem.)
gatortpk - Réponse
I have to add to my previous comment about switching a mid-2009 15 inch MacBook Pro display to a late 2008 MacBook Pro. The reed switch that causes the computer to sleep when closing the display is on the other side. I tested this by holding a broken display (which has lots of magnets across the top) near the right side and this 2.53 GHz late-2008 Unibody MacBook Pro went to sleep. The magnet for the reed switch on the mid-2009 display is about halfway up the left side of the display. So I didn't notice this until I tried to close the MacBook and the backlight stayed on.
So while the display works perfectly and the hinges, camera cable, and LVDS cable match, the reed switch magnet is on the left side now (that meets the ExpressCard/34 slot, instead of the SD Card slot) instead of on the right (near the security slot) where the actual reed switch is for the late-2008 MacBook Pros.
I can just choose sleep from the Apple Menu every time, or put a tiny "refrigerator" magnet on the right side of the display.
gatortpk -
So I managed to do all this perfect except now my wifi card isn't recognised. I did miss out step three, which may well be my fatal error. I've ordered a new wifi card and I hope swapping this out will fix it. Anyone come across this?
Michael Taylor - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 19
30 derniers jours : 77
Total : 145,004
