Aller au contenu principal
Remplacement de l'écran complet du Fairphone 2
Ce dont vous avez besoin
  1. Remplacement de l'écran complet du Fairphone 2, Coque arrière (d'une seule pièce): étape 1, image 1 de 2 Remplacement de l'écran complet du Fairphone 2, Coque arrière (d'une seule pièce): étape 1, image 2 de 2
    • En commençant par un coin et en continuant tout autour de l'appareil, détachez la coque arrière.
    • Retirez complètement la coque arrière.
    My cover is broken - the rubber is lifting from the hard plastic. What can I do? Where can I purchase replacement cases? Perhaps the iFixit app could affiliate with the parts suppliers and host a link for when parts go missing or broken.
    Osh Gates - Réponse
    Thanks for the hint. We added a link to the spare part directly from Fairphone (also for all the other guides and parts). Be aware that Fairphone only ships to European continental countries as stated on their page: https://support.fairphone.com/hc/en-us/a...
    Tobias Isakeit -
    It wasn’t obvious that the outer rim of the cover alaso need to be unclipped after the back cover was removed.
    Once I did that, everything was easier.
    Stephen Morton - Réponse
    It wasn’t obvious that the outer rim of the case also needed to be removed. Once I worked this out, everything was much easier.
    I am with Stephen Morton. I didn’t understand that there was an independent rim, but once I saw Stephen’s comment, it was quite easy. I think you should add this as a stage in this process.
    M ichael Cross - Réponse
    The image is misleading. The black rim and the back cover are two different items and do not come out together. The first to be removed is the back cover, here the transparent item, and then remove the black rim in the opposite direction as the back cover. Please fix the image, as it can be risky to try to do it as shown.
    Domingo Alvarez Mendez - Réponse
    I’ll add to what other people are saying, trying to raise the topic for a change. You cannot remove the cover as a whole, it has two pieces that must come separately.
    Aloïs Glibert - Réponse
    The above confusion comes from the fact the picture shows the original 1-piece cover with a soft rubber rim, whereas all recent FP2 are sold with the new slim cover that comes in 2 part : first remove the back, then the front part. Hope this helps!
    -> the pictures should be updated as they are not accurate for new users most probably needing the help now
    tonidekohlanta - Réponse
    We have a separate guide for replacing the slim case version of the back cover / bumper. You can find it here: Remplacement de la coque slim du Fairphone 2
    Tobias Isakeit - Réponse
  2. Remplacement de l'écran complet du Fairphone 2, Batterie: étape 2, image 1 de 3 Remplacement de l'écran complet du Fairphone 2, Batterie: étape 2, image 2 de 3 Remplacement de l'écran complet du Fairphone 2, Batterie: étape 2, image 3 de 3
    • Poussez la batterie vers le haut du smartphone.
    • Retirez la batterie du smartphone.
    It isn't necessary to remove the rim if all you are doing is changing the battery. That becomes necessary if you are to proceed farther into the phone.
    It might be good to begin by saying switch the phone off. The Fairphone is for everybody and most will have no experience of disassembling electronic devices.
    Jim Kinnibrugh - Réponse
  3. Remplacement de l'écran complet du Fairphone 2, Écran complet: étape 3, image 1 de 3 Remplacement de l'écran complet du Fairphone 2, Écran complet: étape 3, image 2 de 3 Remplacement de l'écran complet du Fairphone 2, Écran complet: étape 3, image 3 de 3
    • Après avoir enlevé la batterie, vous pouvez débloquer l'écran complet.
    • Retournez les deux commutateurs bleus à la position intérieure.
    • Faites glisser l'écran complet vers le bas du smartphone.
    Being technically nervous I couldn't do this. I didn't know how much pressure, pull or push was required.
    Roger Halford - Réponse
    After I'd watched the video my confidence increased!
    It was a bit stiff and not so easy.
    I have not this easy access to the two blue switches. How Can I do that?
    Anne - Réponse
    Super, nachdem ich’s im Video gesehen habe, war es supereasy, vielen Dank!
    Imke - Réponse
    You don´t mention taking the rim off the display first. That stymied me completely. Do add that to your otherwise clear and helpful instructions. Best wishes - Walt Patterson
    Walt Patterson - Réponse
    This guide is based on the old bumper made in one piece. We should update to the sandwich bumper with a top and bottom part.
    Tobias Isakeit -
    I agree. Took a while to figure that one out!
    Jenny White -
    Sorry, I can not slide away the display assembly to change the main camera module. The 2 blue switches seem to be locked. Cristiano, Italy
    Cristiano Gillardi - Réponse
    I replay to myself: I did it at last! ! But it was very, very, very, very hard!
    Can’t get any movement at all on screen been trying for over an hour and others too ! there is no way to grip it as its so slippery have tried putting as much presure as possible on display by pushing far end of it with thin plastic implement and endless wiggling and pressing of every possible part of lower case no joy ! feels like its attached at mid sides. Elinor Rivers
    Elinor Rivers - Réponse
    try sliding along the display while applying some pressure two or three times. it worked really easily for me
    Elisa Werner - Réponse
    I could slide the display case off very easily after watching the video, but when it came to doing the sequence in reverse I was fiddling about for ages trying to ‘slide’ it back on, until I realised this just wasn’t going to work and needed to click it back into place. Posting here in case this is helpful for others.
    Rachel Neat - Réponse
    • Une autre manière de faire glisser l'écran complet pour l'ouvrir.
    Impossible de déplacer l'écran vers le bas chez moi. Je n'ose pas forcer... c'est normal?
    benbahmedf - Réponse
    I can not slide the display assembly. Some help?
    Laura Ivorra - Réponse
    The display sits very tight.
    So you need to gently apply a little force to slide it open the first time.
    It is hard to get a good grip on the two parts for a successful "magic move".
    Leider kann ich weder mit "little force" noch mit "much force" das Display nach der Entriegelung bewegen. Wer kann mit mehr Details helfen?
    Christine Heckmann - Réponse
    It did work for me. Make sure, you have unlocked the blue switches in step 3 (sorry, had to mention that). if you can't get a grip, you might try to lay a ruler or two credit cards on top of each other on a table that is tight at the wall,
    - place the ruler/credit cards on the table and just attaching the wall
    - place the PF2 with the display upside down on the table in front of the ruler/credit cards with the blue switches towards you and the headphone plug attaching the ruler/cards.
    - then gently but with increasing force push your two thumbs towards the top of the main FP2 unit (or use more fingers to push both in the centre as well as on the two edges). make sure you push horizontally and that the ruler is not higher than the border of the display unit (1.5-2 mm).
    (hope i could explain myself in and understandable way! ;-) )
    metaworx - Réponse
    Thank you a lot ! This worked for me.
    Nicolas Dudermel -
    Thanks, it worked for us as well.
    deRahier -
    great tip! Thanks so much
    Matthew Kelly -
    Really helped! This way finally worked for me. Thanks :)
    Imogen Michel -
    thank you !!
    Claire Hahn -
    Perfect Metaworx, it worked for me as well :)
    siohdk - Réponse
    Your nails are slightly long? You are lucky. Hold the phone with the screen on your right palm with the blue bits facing your body. Make sure your fingernails are holding the top of the screen. Push the back of the phone with your left hand. It worked for me.
    Askateth - Réponse
    Mit einer alten Haltekarte für SIM Cards als Hebel habe ich das Display vorsichtig abgeschoben
    Joachim - Réponse
    Unglaublich fair, dass ich mich mit diesem Kack alleine beschäftige - wenn ich so weitermache, werde ich demnächst die Trümmer meines Fairphones wahrscheinlich durch Ungeschicklichkeit so beschädigen, dass es unbrauchbar ist!
    Ralf Kiefer - Réponse
  4. Remplacement de l'écran complet du Fairphone 2: étape 5, image 1 de 1
    • Retirez l'écran complet.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
37 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Tobias Isakeit
Membre depuis le 03/31/14
117 462 Réputation
188 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 528 tutoriels rédigés
7 commentaires
Bonjour ! Es-tu bien sûr d'avoir déplacé les deux languettes bleues vers l'intérieur pour libérer l'écran ? Si oui, n'hésite pas à appliquer une certaine force sur l'écran (appuyer et déplacer vers toi).
Oriane Petit - Réponse
Keine chance das Display zu bewegen. Nach 1h versuchen und allen FP2 Tutorials Videos bin ich immer noch gleichweit. Definitiv Verbesserung würdig. Für weitere Tipps bin ich dankbar, wird es sonst wieder zurück senden :-(
Christian Rapp - Réponse
Ich habe keine blauen Schalter, ich rede vom FP 1U, ist das korrekt?
Birgit - Réponse
FP 1U: Ich habe keine blauen Schalter.....
Birgit - Réponse
The Display seem to be stuck completely, any tips on how to move it?
siohdk - Réponse
Managed it eventually but the “sliding” bit is really not that easy.
theextraone - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 24
Total : 17,434
